how to close the spot covers ?
WesleyB
Has thanked: 7 times
Post by WesleyB »
Hi,
i have buy some spot covers, but I don't find the way how to close ?
Someone have these system or an idea ?
Thx
MK1 Austin Cooper 998cc 1967 Smoke Grey
http://mk1-forum.net/viewtopic.php?f=6&t=26813
Polarsilver
Has thanked: 37 times
Been thanked: 51 times
Re: how to close the spot covers ?
Post by Polarsilver »
Cable Tie ;) ..i seem to remember the original Cover elastic was sewn together then Lamp Cover just pulled on/off over the Lamp.
originals had a small window so it could be seen if the Lamp was left switched On.
WesleyB
Post by WesleyB »
Thx, the easy way cable tie. I have do that and cut the metal of. Thanks , that's good !
LarryLebel
Post by LarryLebel »
Somebody forgot to bend a hook in the key-shaped side.
GraemeC
Been thanked: 7 times
Post by GraemeC »
I would’ve though you push the long part through the other as you have done and then bend it back on itself to form a hook?
WesleyB
Post by WesleyB »
Indeed, I thought so too. But isn't really simple if you want to pick up quickly during rally.
With the cable tie , I brought them together. There is enough stretch to put over them.
