MK3 Washer pump
MK3 Washer pump
Is the MK3 manual screen wash pump bracket the same as a MK2 ?
Either way, does anyone have to sell me ?
Many thanks.
Many thanks.
- Andrew1967
Re: MK3 Washer pump
If it is the same as a Mk2 (which I cant see why it is different as its the same crash pad), I've got one
Re: MK3 Washer pump
Depends on the age of the mk3.
Early cars with ignition key in switch panel and toggle switches had mk2 type washer pump position. Early cars with rocker switches and column lock still had mk2 type pump position. Cars from around 1971 with column lock and rocker switches had the pump in the switch panel where the ignition key used to be.
- Andrew1967
Re: MK3 Washer pump
I’ll post up a photo of the bracket I have tomorrow evening, but it is the correct type
- Andrew1967
- Andrew1967
Re: MK3 Washer pump
Sorry for the delay .. lots of family issues
Here it is ..
Here it is ..
- Andrew1967
