MK3 Washer pump
morris-miner
MK3 Washer pump
Post by morris-miner »
Is the MK3 manual screen wash pump bracket the same as a MK2 ?
Either way, does anyone have to sell me ?
Many thanks.
Andrew1967
Re: MK3 Washer pump
Post by Andrew1967 »
If it is the same as a Mk2 (which I cant see why it is different as its the same crash pad), I've got one :)
imack
Been thanked: 9 times
Re: MK3 Washer pump
Post by imack »
Depends on the age of the mk3.
Early cars with ignition key in switch panel and toggle switches had mk2 type washer pump position. Early cars with rocker switches and column lock still had mk2 type pump position. Cars from around 1971 with column lock and rocker switches had the pump in the switch panel where the ignition key used to be.
morris-miner
Re: MK3 Washer pump
It’s for the earlier MK3.
Andrew1967
Re: MK3 Washer pump
I’ll post up a photo of the bracket I have tomorrow evening, but it is the correct type
morris-miner
Re: MK3 Washer pump
Many thanks!and if you’ve got one I’ll buy it if I may.
Cheers all.
Andrew1967
Re: MK3 Washer pump
I’m away this weekend but will post it up on Monday and it will be available ;)
morris-miner
Re: MK3 Washer pump
Many thanks Andrew, PM me and I’ll send you my address.
morris-miner
Re: MK3 Washer pump
Any news on this one Andrew ?
Andrew1967
Re: MK3 Washer pump
Sorry for the delay .. lots of family issues
Here it is .. :)
morris-miner
Re: MK3 Washer pump
👍🏻 perfect.
Please PM me with cost and payment details.
Many thanks, Garry.
Andrew1967
Re: MK3 Washer pump
PM sent Garry :)
