I key fits all?
- Has thanked: 41 times
- Been thanked: 10 times
I key fits all?
My question with a 1965 Mini - did it have 1 FS key to fit door, boot and ignition or was the ignition a seperate key? thanks in advance?
- Has thanked: 7 times
- Been thanked: 20 times
Re: I key fits all?
Thank you - have managed to read the boot and door locks and hopefully then the original ignition barrel is in the car and might be the same....
Re: I key fits all?
Apart from that, your Key may also work on other Cars.
I remember at the IMM 2007 in Roskilde, my Car was always parked in an other space at the Hotel as whe had fun parking each other's Car away...
- Has thanked: 181 times
- Been thanked: 64 times
Re: I key fits all?
If you find you have a mish-mash there, a decent Locksmith can easily sort them to be keyed the same.richardACS wrote: ↑Thu Jan 12, 2023 7:32 pmThank you - have managed to read the boot and door locks and hopefully then the original ignition barrel is in the car and might be the same....
- Tds76
Re: I key fits all?
It's really easy to key-alike at home as well with these locks. Should take no more than 10 mins once you have the lock barrels on your work bench. I can post up an instruction if people want it.
Cheers, Paul.
Cheers, Paul.
1970 Morris Mini K1100
