Square Hole Hub Caps
rogerotto66s
Post by rogerotto66s »
1966 Austin Cooper S
LHD, Wet, Personal Export
I seldom see these hub caps which I believe are original to my “S”.
I can not find any info.
Can anyone provide Info?
Also they are very hard to put on without damaging the paint on the wheel.
Any thoughts?
I did see the suggestion re: removal - Weave a rag or rope through some openings and pull.
Roger Williams
cmiller
Re: Square Hole Hub Caps
Post by cmiller »
Don't believe these were ever used on a 'S' of any vintage. I believe all 'S' used the Baby Moon style hubcaps.
Chris Miller
nickacb
Post by nickacb »
As far as I know those hubcaps are only for early minis 1959 to later 1960. I can confirm they will damage the paint of the wheels if taken out with a screw driver. The safest way is to use a piece of cloth
rogerotto66s
How to easily get them on?
I used rubber mallet. Really chews up the paint. Must be an easier way?
Roger Williams
'S'-type
Has thanked: 38 times
Been thanked: 14 times
Post by 'S'-type »
As above, they were only used on the 1959 deluxe models.
They are not right for an S. Unless you're not aiming for originality and just like them I would sell them as they should make good money.
Has thanked: 236 times
Been thanked: 208 times
rogerotto66s
Thanks to all.
Now I need to swap/sell my square hole trim for baby moon trim.
Roger Williams
iain1967s
Been thanked: 7 times
Post by iain1967s »
A Mk1 S would have LP882 / 21A1282 cream coloured 3.5”x10” wheels as factory standard, or LP883 / 21A1286 cream coloured 4.5”x10” as option. Both wheels use a 88G337 “baby moon” chrome hubcap.
The current repro hubcaps available from MiniSport and minispares are a good match to the originals. I have them on my ‘67 S.
rogerotto66s
Now I have to set a price for the square hole hub caps. Mine are chrome (magnet sticks). I have a few people interested.
Also have a lead on original baby moon hub caps. Anyway to tell original from reproductions?
Roger Williams
Costafortune
Has thanked: 31 times
Been thanked: 38 times
Post by Costafortune »
Square hole hubcaps were Austins for a short while and half moons were Morris, standardised to half moons after a year or so and certainly by 1961.
Half moons clipped over the wheel hub and the square hole ones pressed into the wheel rim, scratching the paint and causing rust.
1071 S
Post by 1071 S »
rogerotto66s wrote: Thu Sep 08, 2022 1:20 pm Thanks
Originals will have dents in them :lol:
Dime a dozen Down Unda ... Every Oz Mini for at least 10+ years had them.... Would think it not much different wherever you are.
Cheers, Ian
rogerotto66s
Thanks all for comments.
Were originals chrome or stainless steel?
I have received feedback for both! Who is correct?
Roger Williams
