1275s pre verto clutch disc
ateichert
Post by ateichert »
Is it possible to fit the disc backwards? When I was assembling the clutch I would have sworn the disc was marked backwards. When installed as per marked, The flywheel would not go on. So I turned disc over and every thing went fine. But now I am wondering?
Thanks Mike
timmy201
Been thanked: 39 times
Re: 1275s pre verto clutch disc
Post by timmy201 »
Yes it can go on backwards
Mine was marked gearbox from memory, which goes on the opposite side to the engine (gearbox marked side facing the clutch arm). It’s a little confusing on a mini as the gearbox and engine are on the same side of the flywheel
Has thanked: 183 times
Been thanked: 65 times
ateichert wrote: Fri Mar 18, 2022 12:45 am Is it possible to fit the disc backwards?
Anything is possible but as you found, you'll struggle (ie, won't) to get it together if it's the wrong way around.
CooperTune
Post by CooperTune »
Busy building 998 units opened the clutch disc box and was confused by the markings. Clear it would never assemble backwards so why bother marking? If you think about the design it can be understood. Assembled and never looked back. Steve (CTR)
