Distributor connections and tacho
- woodypup59
- Has thanked: 8 times
- Been thanked: 22 times
We've had a car arrive at the workshop as a non-runner with this electronic distributor which has two connections - a pink and an orangy brown.
Which is permanent +12v and which is the switched side of the coil ?
The car has this tacho fitted. The sensing loop is in the white wire between the ignition switch and the coil.
Is that right ? I'd have thought the tacho sense would be between the coil and distributor - or is it something to withe the electronic dissy.
The owner says it has worked like this but I'm skeptical and don't want to let the smoke out.
Its a 1275 A+.
Its a 1275 A+.
- Been thanked: 7 times
Re: Distributor connections and tacho
Does this description of the module help?
- Dr.Mabo
- Been thanked: 44 times
The tacho was / is connecet correct in the was you mention it. To make it more clear, have a look on the SMITHS diagram for the tacho.
- woodypup59
Thnaks Dr Mabo - that confirms the tacho wiring.
Can anyone confirm the electronic dissy connections ?
- woodypup59
I'm afraid not because we don't have white and white / black wires.
I was hoping someone might recognise the pink and orangey brown wires.
But it tells you which pin is which - just trace or multimeter your wires out.
Normally in Minis pink is a resistive +ve and brown is a permanent unfused +ve so it may be that your wiring isn't original
- woodypup59
OK thanks for that. The whole car is a hybrid / mixture of parts, which makes it difficult to trouble-shoot.
Unfortunately the M/S description " .. ignition module fitted to all standard electronic ignition distributors (non injection) looking at the front of module, negative is on the left. positive on right ... " is ambiguous.
What does looking at the front of the module mean I wonder ?
I might nip dowm to Potters Bar and see if I can examine one of the leads YMV10064
- iain1967s
That tacho is an RVI. It is unlikely to work correctly with an electronic ignition.
But you can get it converted at spiyda to RVC.
https://spiyda.com/smiths-rvi-rvc-conversion-board.html
- Hipwell
- Been thanked: 3 times
Distributor wiring for the DAB 118 type amplifier (Which work really well)
http://www.cosmoselectric.com/Prodetail ... lNub=10261
http://en.gasgoo.com/showroom/sxboyi201 ... 11535.html
The centre pin doesn't need to be connected, needs to be negative earth. Just a wire to either side of the coil. You want a DLB 198 coil with no ballast resistor.
