Speedwell temperature gauge connecting
Been thanked: 9 times
Just bought this Speedwell temperature gauge,
what is the best way to connect it on my engine ?
Kees.
Re: Speedwell temperature gauge connecting
:D Thanks to Mark F. for helping me out and is selling me the missing part :P .
Kees.
Been thanked: 10 times
The adaptor will be on its way to you on Monday :)
:lol: will see it within three weeks, the post is so slow from te UK to the Netherland.
Thanks Mark.
On it's way today.
I found this thermostat house to connect my thermostat indicator in. :D
It's from an Austin Allegro and will work well.
Kees
That thread looks very large! also, beware that the capillary tube will need supporting where it goes into the head, if you don't it will break.
:| Thanks for the advice, to be continued.
Kees
timmy201
Been thanked: 38 times
Post by timmy201 »
How about a 12A408?
:roll: Even better opinion, hope to find one as an option. Thanks mate.
Kees
timmy201
Post by timmy201 »
Plenty for sale over in Aus if you need one :D
:) Thanks but a bit to expensive to get over here.
Kees
:roll: :roll: I don't think it will work with the engine steady
:) The first set up is ready.
Kees
On left the picture the one I bought from Mark, using that one seemed not to work together with the part I already had. Did ask my nabur if he could think of something to make it fit.
He made a complete new one for me so the one from Mark is left on the shelf. This is what I call serious oldskool "WORKS" craftsman ship.
;) Kees
Ronnie
Has thanked: 12 times
Been thanked: 30 times
Post by Ronnie »
UHR850 wrote: Fri Jan 07, 2022 10:46 am On left the picture the one I bought from Mark, using that one seemed not to work together with the part I already had. Did ask my nabur if he could think of something to make it fit.
;) Kees
When fitting Amot control equipment into thermocouple pockets (1960's :shock: ) on cooling water rails, the fact that the sensing bulb is not in direct contact with the cooling medium heatsink compound was always advised.
Also Kees make sure that bleed all air out you don't want your sensor sitting in a big air bobble.
https://www.amot.com
Many thanks I will keep that in mind.
I also have the original gauge in the dash.
Kees
