Light flywheel and pressure plate
davidmuir
Has thanked: 18 times
Post by davidmuir »
Hi, Which supplier of the above does 'everyone' use?.......for 1312 with piper cam ,big valves etc- fast road use.
Thanks, D
Minigman
Has thanked: 10 times
Re: Light flywheel and pressure plate
Post by Minigman »
I’d go with one of the MED ones. Stage of tune will determine which would suit you best.
I have one of these in a fast road 1330
https://www.med-engineering.co.uk/med-s ... t-assembly
- You must have shot an awful lot of tigers, Sir.
- Yes, I used a machine gun ;)
Been thanked: 10 times
If it's for the road you can't beat the Minispares one for value.
Personally, I wouldn't use an ultralight on the road.
http://minispares.com/product/Classic/C ... o%20search
http://minispares.com/product/Classic/C ... |Back%20to
Make sure you get the correct type for your starter.
Fanfaniracing
Has thanked: 7 times
Been thanked: 22 times
Post by Fanfaniracing »
I have this one in my 8 Port.
Works very well...
https://www.med-engineering.co.uk/clutc ... -light-st3
Charlynsane
Post by Charlynsane »
Avoid MED engineering!
Worst spares ever, worst customer service
I would go for a SH, swiftune or KAD
I had two MED flywheel,
Twice bad machined, not flat etc..
I just ordered a KAD, a masterpiece
davidmuir
Post by davidmuir »
??SH?
m1cH1
Post by m1cH1 »
davidmuir wrote: Thu Nov 25, 2021 7:11 pm??SH?
Probably https://www.shengineering.co.uk/
Hipwell
Post by Hipwell »
The SH one as nice as it is(I’ve had one in my hands) is less than ideal for a road car.
CooperTune
Post by CooperTune »
The later OEM pre verto flywheels with the huge center are just plain heavy. Machine shop lightening and balancing with current wait times and cost makes new reasonable. Of course with a complete new assembly I balance every engine. I have used all of the different lighter flywheels MSC offers as well as the back plates. I have also used the Verto light steel A+ ones.
One thing I learned ( I'm sure everyone else knew ) the ring gear for the verto flywheels are the thin ring gear for pre engaged starters used with light flywheels. Steve (CTR)
Vegard
Post by Vegard »
Which cam are you using?
davidmuir
Post by davidmuir »
an 'old' Piper 1BY which I think is equivalent to a 731.
