It has a rear tacho drive on it..needs blanking off like on the original one.cpr1 wrote: ↑Thu Sep 16, 2021 10:15 pmI guess this one takes some kind of pump/exhauster at the rear.Nick W wrote: ↑Thu Sep 16, 2021 2:03 pmSounds like this one Jim can make from classic&vintage dynamos251 ENG wrote: ↑Thu Sep 16, 2021 1:22 pm I was told there was one used on early lotus engines that was similar. That was from a reconditioning specialist, he said he could replicate something similar for about £350 and that was about 10 years ago .
The ends are cast iron and have special heavy duty bearings I believe.
Works Dynamo
- Nick W
Re: Works Dynamo
Up North in Sheffield
- Nick W
Re: Works Dynamo
It's even got the massive weld in the correct place, just needs the tacho drive blanking and painting black.
Re: Works Dynamo
Hi Nick
See the AEG305 Head thread. Another picture of the dynamo with the big weld on it and the end plate as per works. On a Sebring Sprite.
Have you determined the diameter of these dynamo with the large weld?
Again, it looks wider in the Sprite photo.
- Nick W
Re: Works Dynamo
They are 4" same as a standard C40 the ones Jim builds use a C39 case which is also 4" . It must be an illusion on some of the old images, unless they are using the C45 case
- Nick W
Re: Works Dynamo
Here is an image of EJB with the same dynamo
