spoon.450
Posts: 1808 Joined: Fri Jan 20, 2012 9:13 pm
Been thanked: 1 time
Post
by spoon.450 » Tue Jul 20, 2021 8:43 am
I’m sure it’s a simple, obvious answer, but I’ve got a bit confused and feel slightly stupid even having to ask !
On a NEGATIVE earth car, running standard points distributor set up, which terminal on the coil should have the 12 v ( ignition switched ) feed, + or - ?
Thanks in advance.
111Robin
Posts: 2633 Joined: Mon Dec 19, 2011 7:59 pm
Has thanked: 3 times
Been thanked: 17 times
Post
by 111Robin » Tue Jul 20, 2021 8:52 am
Feed from ignition switch goes to coil + on negative earth
Ronnie
Posts: 1287 Joined: Fri Jun 25, 2010 5:37 pm
Has thanked: 12 times
Been thanked: 31 times
Post
by Ronnie » Tue Jul 20, 2021 8:57 am
+ and the - goes to earth through the distributer to complete your circuit.
spoon.450
Post
by spoon.450 » Tue Jul 20, 2021 1:13 pm
Thanks chaps
