Cooper S Camshaft ID
rogerotto66s
Post by rogerotto66s »
I just removed my camshaft from my 1966 Austin Cooper S.
It is a pin drive camshaft which I am told is original for the “S”.
I do not see any markings.
I understand somewhere there are pictures or ways to identify the cam visually.
Any help would be appreciated.
Roger Williams
LarryLebel
Re: Cooper S Camshaft ID
Post by LarryLebel »
3/8 or 1/2 lobes?
rogerotto66s
My camshaft has 1/2” lobes.
Roger Williams
whistler
Has thanked: 18 times
Post by whistler »
Here's a snip of the parts manual showing the changeover point to the 510 camshaft.
Thorp
Post by Thorp »
If it’s a 66 car it should have (if original) an Aeg510, which has 1/2 inch lobes and 1 ring on it I seem to recall.
Andrew1967
Post by Andrew1967 »
I’m pretty sure the 148 doesn’t have any identifying marks whereas, as previously said, the 510 has one ring.
moita
Post by moita »
148 don't have any marks :) I can confirm.
bwaminispeed
Post by bwaminispeed »
AEG 630, same spec as all 998 Coopers (3/8" Lobe the bigger motors had 1/2" Lobes), Cooper S till changeover to AEG510, and, 1100 and 1300 engines.....
rogerotto66s
Thanks all.
Looks like I have the original camshaft - AEG510.
My engine (9FSAY42201) is beyond the changeover point of 9FSAY40006.
My camshaft has 1/2” lobes, pin drive, 1 ring.
I sent my camshaft to Delta Cams (Tacoma, Washington, USA) and it was returned with a red band.
What does this designate?
Roger Williams
bwaminispeed
Only Delta Cams would know that........
