64 Cooper S Speedo
64 Cooper S Speedo
Check out the shift points on this sucker, 42, 60, and, 85 MPH........
Yikes, what revs would those equate to assuming 3.44 gearing, and, close ratio 333 box......
Would seem to me to be well into the 7s......
- iain1967s
- Been thanked: 7 times
Re: 64 Cooper S Speedo
85 MPH is approx 6400 RPM in 3rd for the Mk1 'S' C/R box w/3.44 FD according to John's calculator
Pretty close match to the same ~6500 change points for all 3 gears on that speedo.
http://www.guess-works.com/Tech/ratio.htm
- iain1967s
yeah, the tool doesn’t have all the combinations, but that one was the closest match.Minisprinter wrote: ↑Sun Apr 25, 2021 11:11 pmI think you've plugged in the straight cut gearset with the 2.57 1st gear instead of the 333 1st gear 3.2 ratio
- Has thanked: 18 times
- Been thanked: 50 times
I am trying to see the final two numbers on the speedo code, is it 32???
If so a 63-4 pre voltage stabiliser model for the optional gears and 'axle' as they call it. Must be a rare beast these
I have a 64 1071 S also a single tank dry car. The speedo is marked 30 / 50 / 71 the gear box was liberated before I found the car. Steve (CTR)
