CV boot rubbers
- johnv
CV boot rubbers
I know there’s been numerous threads on this, but if I may, where is generally thought to be the best source at the moment? Mine have perished before the car even turned a wheel ..
Mk2 1968 Cooper 998 TPL555F
Mk1 1965 Cooper 1275 BFC110C
Re: CV boot rubbers
I've used italian made outer CV boots from another car ( citroen maybe ? ) , they are good quality if you are not worried about originality.
I will get the par number over the WE and share here, kept the boxes somewhere.
Re: CV boot rubbers
Part Number D8151E , AutoFren brand ( actually spanish ) ,
it's a Ford Fiesta Mk2/3 CV boot, and listed also as compatible with Austin Metro CV joint.
Fiesta boots should be very easy to find in UK.
Luis
- johnv
Re: CV boot rubbers
Thanks Luis I'll check them out
- Has thanked: 186 times
- Been thanked: 65 times
Re: CV boot rubbers
Luis, are these the ones that come with the Metelli CV's ?LuisM wrote: ↑Fri Feb 26, 2021 11:03 amI've used italian made outer CV boots from another car ( citroen maybe ? ) , they are good quality if you are not worried about originality.
Luis
I've found them to be quite a good boot.
Re: CV boot rubbers
Hi Chris,Luis, are these the ones that come with the Metelli CV's ?
No , these are spanish ones , boxes similar as the one from pic below. I have also in use an italian Metelli set when they were available here listed as metro CV boots , after 6 years they are still ok.
The good thing is that for the Ford Fiesta there are still some good quality brands stocking them .
Luís
Re: CV boot rubbers
Thanks Luis - nice to have some alternatives and good to know that there's one from another car that'll fit, though, I'm sure if we sat down with a Catalogue, we'd find quite a few.LuisM wrote: ↑Sat Feb 27, 2021 3:15 pm
Hi Chris,
Luís
- iain1967s
- Been thanked: 7 times
Re: CV boot rubbers
Japanese CV boots available here:
https://classicminisjapan.com/new-parts ... er-cv-boot
Also has pot joint inners:
