Steering Column Shroud
rogerotto66s
Post by rogerotto66s »
My shroud could use a clean-up.
Is this paintable?
If yes, what type of paint?
Roger Williams
Polarsilver
Has thanked: 38 times
Been thanked: 52 times
Re: Steering Column Shroud
Post by Polarsilver »
Painted mine with Plasticote using their primer & top coat in a rattle can .my cover had gone brown so pleased with the results.
rogerotto66s
Polarsilver wrote: Tue Nov 17, 2020 9:08 am Painted mine with Plasticote using their primer & top coat in a rattle can.
Do you recall which type of Plastikote?
Roger Williams
Polarsilver
I used the following .. "PlastiKote" (the perfect finish),, comes in a 400ml Rattle Can .. Multi surface Spray Paint ..recoat anytime
the cans barcode no 50055018109523 .. Black Gloss.
suitable for wood, metal, plastic,stone,wicker & crafts
made by MOTIP DUPLI.BV made in Holland
Sorry that that i cant find the PlastiKote Primer Paint that i also used.
Hope this helps .
Been thanked: 10 times
Don't bother painting it. Give it a good rub down with some toothpaste then polish with brasso.
Good as new.
rogerotto66s
I tried toothpaste but not abrasive enough.
Then used 220 and 320 grit wet/dry paper followed by copper polish.
Much better but still some work to do.
I will purchase finer grit and try again.
The top piece is the before and the bottom picture is the after.
Compare bottom to previous posted picture and you can see the staining is gone.
Roger Williams
GraemeC
Been thanked: 7 times
Post by GraemeC »
Wire wool or a fine scotch brite pad?
rogerotto66s
Here is my finished product.
I am pleased with the final result!
Used 220, 400 and 600 wet/dry paper, Brasso and a bit of shoe polish cream!
Buffed it with my shoe polish brush!
I used the shoe polish since the Brasso smelled a lot like shoe polish!
I tried buffing with a buffing wheel but the bakelite plastic did not seem to like it (not sure why).
I was going to use Autosol but Brasso was more readily available and more reasonably priced.
Thanks for all the tips.
Roger Williams
