Lower Body Trim
kensk77
Lower Body Trim
Post by kensk77 »
Our car is a 1960 Morris Mini De-Luxe (per the Heritage Museum). It is missing the 6 piece lower body mouldings. I can source them in body colour without much difficulty but I think on a De-Luxe they should be bright metal.
Hoping to get confirmation on this point.
thanks,
Brian
Brian
AndyPen
Has thanked: 18 times
Been thanked: 51 times
Re: Lower Body Trim
Post by AndyPen »
Stainless I’d imagine Brian?
InnoCooperExport
Has thanked: 4 times
Been thanked: 9 times
Re: Lower Body Trim
Post by InnoCooperExport »
Phoenix trim do it by the roll, but I'm not sure if theirs has the 100% correct profile I've never seen it myself. I've spoken to Minispares about it quite some time ago as theirs was out of stock. They told me they couldn't get the correct Deluxe shape trim (with the extra lip) in the bright chrome anymore as the process for chroming the plastic had been forbidden. They were waiting on samples from the spec one which was a tad more matte. Don't think there's been any movement on that since.
bwaminispeed
Re: Lower Body Trim
Post by bwaminispeed »
1960, should have stainless steel (not plastic), 3 pieces per side.......
Re: Lower Body Trim
Post by Old English White »
I'm not sure that is correct. None of the early "deluxe" Minis I've owned had the stainless trim.
Rubber Sprung
Re: Lower Body Trim
Post by Rubber Sprung »
1960 would be De Luxe plastic trim .
kensk77
Re: Lower Body Trim
Post by kensk77 »
Old English White wrote: Mon Nov 09, 2020 7:38 am I'm not sure that is correct. None of the early "deluxe" Minis I've owned had the stainless trim.
They were body colour then?
Brian
Re: Lower Body Trim
kensk77 wrote: Mon Nov 09, 2020 2:21 pm
No, they were fitted with the bright plastic trim exactly as in your picture at the start of this thread - as opposed to the metal stainless steel trim which comes in 3 sections per side and was not introduced as far as I remember until the Mini "Super" and "Cooper" models came out.
kensk77
Re: Lower Body Trim
Post by kensk77 »
Old English White wrote: Mon Nov 09, 2020 3:07 pm
thank you, I wasn't aware that the early bright trim was plastic...
Brian
STG95F
Re: Lower Body Trim
Post by STG95F »
Maybe some help , if its a very early 60 build it could of had the none fluted type trim
http://1959miniregister.com/variations- ... r-general/
kensk77
Re: Lower Body Trim
Post by kensk77 »
The car is an early September, 1960 build. I found this online, wonder if it would work.
Brian
bwaminispeed
Re: Lower Body Trim
My first Mini, a 61 Traveler had two piece Stainless trim......the curved bit over the front wheels arches, and, a straight bit from the bottom of the A panel, to the front edge of the wood trim.........
AndyPen
Re: Lower Body Trim
Post by AndyPen »
Been looking at one of my books and didn't realise plastic preceded the steel trims.
kensk77
Re: Lower Body Trim
Post by kensk77 »
I found this on the 1959 Mini Register
Brian
