All together now....'DOOR CARDS!'
snoopy64
Has thanked: 88 times
Been thanked: 14 times
Post by snoopy64 »
Ok, has anyone got any tips on fitting door cards to a built up door??
Kevin
'S'-type
Has thanked: 39 times
Been thanked: 15 times
Re: All together now....'DOOR CARDS!'
Post by 'S'-type »
Have you seen the Newton Commercial guide? Tried to attach a copy here but too large.
It's a PDF. Just search for Newton Commercial door card fitting guide.
snoopy64
Post by snoopy64 »
Ah! ok, thanks will take a look...
Kevin
snoopy64
Post by snoopy64 »
Found it..thanks... looks like the door handles will be coming off :)
Kevin
Here's a link to the newtons door card fitting pdf. The page has print and save options.
https://cdn.shopify.com/s/files/1/1613/ ... 2363880336
AndyPen
Has thanked: 18 times
Been thanked: 51 times
Post by AndyPen »
The Newton ones may need a little trimming I gather - just in case it is those you are fitting?
Polarsilver
Has thanked: 38 times
Been thanked: 52 times
Post by Polarsilver »
Last Summer i spent time taking Newton a pair of my OE Doors to them so they could check their Door Card patterns .. Newton intention were to modify their own Patterns following complaints of oversize .. sometime later Newton send me a test Door Card asking would i fit it.. then comment .. this new size Newton test Door Card fitted all ok without any issues that was until i tried to remove it ..then its a case of some tear damage into the top area of the backing board however the Facia Trim on that re-size test door card was not damaged .. so just make sure there is no need to remove a new Newton Door Card once it is installed.
I later was sent my new brocade full trim kit .. fitted without any issues other than i did again downsize the rear cards backing board in the area of the ashtray to help with easy installation .
My opinion Newton are a company doing a proper job :D
Been thanked: 10 times
'S'-type wrote: Tue Aug 04, 2020 10:43 am Have you seen the Newton Commercial guide? Tried to attach a copy here but too large.
Just copy & paste the address into your message & you can make a link straight to it.
Like this:
https://newtoncomm.co.uk/blogs/news/lat ... mk3-to-mk7
'S'-type
Post by 'S'-type »
Thanks Mark
