Engine vibration
GarysMK1
Engine vibration
Post by GarysMK1 »
Hi gents , Recently put new clutch in car (60 mini seven 850) and also new ring gear on flywheel.
Now, when the engines running, theres a vibration running through the car.
The engine mounts are new.
Anyone had this concern and what was the fix ?
LarryLebel
Re: Engine vibration
Post by LarryLebel »
Did you rebalance the flywheel assembly?
Blacktulip
Post by Blacktulip »
Exhaust fouling the tunnel?
Southwest
Post by Southwest »
Assuming you reassembled the clutch with all the v marks lining up.
bwaminispeed
Post by bwaminispeed »
Some of the new motor mounts are a bit on the hard side, and, transmit more vibration through the body.......
minibitz
Been thanked: 13 times
Post by minibitz »
Ditto the above engine mount suggestion. Genuine mounts have rubber that you can feel compress between your fingers whereas most non genuine mounts have rubber that feels solid. Makes a heap of difference.
AndyB72
Post by AndyB72 »
If you fitted new engine mounts when you changed the clutch I would definitely have a go at changing them before stripping the clutch again, did you save your old mounts, maybe stick them back on and see if the vibration goes.
GarysMK1
Post by GarysMK1 »
Exhaust does not foul. Used non genuine mounts and with it being old, could not see V marks to align diaphram ?
Ive ordered GENUINE mounts and will compare them when off. Also going to remove clutch assembly and rotate clutch diaphram one turn and see how that feels, if still the same, i'll rotate one final time - thats all positions tried. A fiddley job with engine in situ but have to try before my fillings come out !! :)
Southwest
Post by Southwest »
All the clutch parts should have a balance mark
