Can anyone confirm the part number and supplier for the correct flywheel oil seal for early 850 with wet tail crank.?
I see Somerford stock one but if possible I would like to find the right one one via a Bearing supplier or other.
Somerford only have one type in stock (they show two options).
I do have an old seal from a different early engine, which is GACO MIM 154 4862, not sure this is an OE seal though.
Any advice will be much appreciated.
Cheers,
Rich
Wet Primary Gear Flywheel Oil Seal
- Rich997
Re: Wet Primary Gear Flywheel Oil Seal
I used a wheel bearing oil seal, just can’t remember if it was front or rear, not had any issues with it, the original seal was NLA when I did mine
- woodypup59
- Has thanked: 8 times
- Been thanked: 22 times
- whistler
- Has thanked: 18 times
- Been thanked: 6 times
Parts book shows superceded to 22A214. Somefords supercede it to 22A325.
- Rich997
Thanks for the advice.
I will look for hub seals.
Cheers,
Rich
Cheers,
Rich
