Looks like a 998 Cooper engine...
Cole Liggett
Post by Cole Liggett »
I have what looks to be a 998 Cooper short block. D top pistons, two rings between 1/2 lobes. Anyone with more experience able to shed some light or help me confirm if it is a Cooper 998?
Cheers,
Cole
1963 Morris Mini Cooper 997 - 4461 KX
Daz1968
Re: Looks like a 998 Cooper engine...
Post by Daz1968 »
If I had to guess I would say it is a 998 Cooper engine, but block is same as any other 998 from same era as far as I know, pistons are defo cooper, engine number is best giveaway
Cole Liggett
Daz1968 wrote: Thu Jun 11, 2020 8:33 pm If I had to guess I would say it is a 998 Cooper engine, but block is same as any other 998 from same era as far as I know, pistons are defo cooper, engine number is best giveaway
Yeah, I should have mentioned the engine number is gone.
Andrew1967
Post by Andrew1967 »
Yep, 998 Cooper
D tops were only used in 998 Coopers as Daz says.
Blacktulip
Post by Blacktulip »
I think it is a cooper engine as it also has no fuel pump hole which I believe was only the cooper too? Might be wrong
Terence
Post by Terence »
Blacktulip wrote: Thu Jun 11, 2020 8:44 pm I think it is a cooper engine as it also has no fuel pump hole which I believe was only the cooper too? Might be wrong
Regular 998cc Mk2 Minis had an electric pump.
360gts
Been thanked: 55 times
Post by 360gts »
997...bore -62.43mm............998 -64.59mm
997 had a longer stroke as ell. (3.2")
Cole Liggett
Thanks everyone for the info. I think it’s pretty safe to assume this is a 998 Cooper engine. Not that I’ll be using it for my project, this will hopefully get passed on to someone else who is restoring a 998 Cooper.
MiNiKiN
Has thanked: 91 times
Been thanked: 31 times
Post by MiNiKiN »
The Innocenti Mini 1001 (and probably the earlier Innocenti Coopers) had D-top pistons and 12G295 heads too.
CooperTune
Post by CooperTune »
OK it seems we all think of this as a 998 Cooper unit. Of course the D crown pistons are a dead give away. I have a 73 Inno
1001 Cooper. It came to me as a failed Honda conversion missing the power unit and front end, I recently located a 998 Cooper
short block with a spun rod bearing. I have 295 cyl heads, cranks and intake kits. Fellow is asking dollars 350 US and I think it is a fair
deal. I'd like to be able to hone and fit rings to retain the D crowns. Failing that I'll bore and fit press fit flat tops. What value
would we place on a a properly rebuilt 998 Cooper unit? I do not have a title for the Inno and may consider parting it out
completely. I also have a complete 997 project with very , very rough shell. While I do have the title this one may get parted
out as well. Steve (CTR)
