twin carbs
- IAIN
twin carbs
Would a cooper S have the vacume 'take off ' on the Right Hand carb blocked or was the 'take off' tube not there ?
- Been thanked: 6 times
Re: twin carbs
Many sets of original cooper s carbs have the tube on the carb body but it is blocked off
- Andrew1967
Re: twin carbs
I have a couple sets of 1071 and 1275 carbs with blanked off take off spouts.
I thought it odd to start with but a post on here a few years ago put my mind at rest.
- IAIN
Re: twin carbs
The one I have, the tube is soldered up I think. I wasn't sure if that was correct. Thanks .
Re: twin carbs
my original cooper air cleaner housing (double air cleaner has a tube take off - what is that for?
- Has thanked: 18 times
- Been thanked: 51 times
Re: twin carbs
Yes on early cars without a PVC valve, as when they were fitted it was just left connected to nothingbwaminispeed wrote: ↑Mon Apr 20, 2020 2:19 pm That connects to a similar tube on the rocker cover.......
Re: twin carbs
That's what I thought, early cars only.......
I have an August 25 64 1275 S, and, this is one of the things I need to find out......
That change to Hydro only says September 64, lot of days in September 30 to be exact........
My car has a wet shell, one of the first, maybe THE first, I don't know........But, it was definitely built as a dry car.....
It didn't come with it's original engine, and, these are all the little details I need to sort out......
Re: twin carbs
Hydro shells were being build before the auctuater switchover. Worked on a 64 shell that had a factory hydro floor and boot floor, but dry bulkhead.
Re: twin carbs
I have a 1966 S wet car with a July build date.
I purchased the car from the original owner.
The Heritage Certificate indicates “Personal Export”.
Below are pictures of my air cleaner and twin carbs.
The air cleaner tube has a screw clamp near the bottom.
What is attached to this tube?
( Added after initial post )
I now understand -
- the clamp is actually holding an extension pipe in place.
- the pipe was intended to pull warm air off the exhaust manifold.
I now understand -
Roger Williams
