Crazy rev counter
- Vegard
Crazy rev counter
I've fitted an Elliot rev counter on my racecar. However, lately at top rpm, the needle has started to bounce. It exceeds 8000 at times, and I know that the engine doesn't. On my last race this weekend, the engine started to midfire at top in fourth as well. I guess this could be related.I'm running Lumenition breaker-less ignition.
Any ideas on what's causing this?
Re: Crazy rev counter
I belive this is the setup with an "eye" inside the distributor ?
If it is, then check the little copperwire, on the bottom plate (from outer housing, to ground plate) this can sometime brake off.
I may have the answer?
My FIA race car had the same problem, and my friends Elva fitted with a BMC FJ set-up.
It seems that if you run a Elliot taco and LUCAS SPORTS (gold) coil, they are not compatible.
You need to fit a diode on the coil, to smooth the signal out. This is the recommendation from Elliot, and it has worked for us both.
I don't have the car in front of me, but when I next look i will feedback what rating it is?
Regards
Paul.........
Regards
Paul.........
- Been thanked: 14 times
Elliott stopped making rev counters a year and a half ago , so don't expect any help from that end.
I've got one on my 7 port thing and its's fine with a cheap coil. Never felt the need for a sports coil especially as they're a bit blingy for me
- Vegard
As a matter of fact, this started when I changed to a gold coil. Seriously
Could the misfire come from this as well?
Only one way to find outVegard wrote:As a matter of fact, this started when I changed to a gold coil. Seriously
When we were racing in the '90s we had loads of problems with the Lucas sports (gold) coil, we swapped to the old SA12 with the brown top http://www.google.com/imgres?q=lucas+sp ... 9,r:4,s:68 and all the problems were solved. It never failed in 3 seizons.
- sandman
Lucas coils are known to cause problems... I would swap back and try.
I always carry a spare - which come to think of it - you now got Vegard (hehehe)
Cheers,
Ed_
Ed_
- Vegard
Indeed, and see where it got me...A lost racesandman wrote:Lucas coils are known to cause problems... I would swap back and try.
