Crazy rev counter
Vegard
Crazy rev counter
Post by Vegard »
I've fitted an Elliot rev counter on my racecar. However, lately at top rpm, the needle has started to bounce. It exceeds 8000 at times, and I know that the engine doesn't. On my last race this weekend, the engine started to midfire at top in fourth as well. I guess this could be related.I'm running Lumenition breaker-less ignition.
Any ideas on what's causing this?
JC T ONE
Re: Crazy rev counter
Post by JC T ONE »
I belive this is the setup with an "eye" inside the distributor ?
If it is, then check the little copperwire, on the bottom plate (from outer housing, to ground plate) this can sometime brake off.
big-un1967
Post by big-un1967 »
I may have the answer?
My FIA race car had the same problem, and my friends Elva fitted with a BMC FJ set-up.
It seems that if you run a Elliot taco and LUCAS SPORTS (gold) coil, they are not compatible.
You need to fit a diode on the coil, to smooth the signal out. This is the recommendation from Elliot, and it has worked for us both.
I don't have the car in front of me, but when I next look i will feedback what rating it is?
Regards
Paul.........
Tim Harber
Been thanked: 14 times
Post by Tim Harber »
Elliott stopped making rev counters a year and a half ago , so don't expect any help from that end.
I've got one on my 7 port thing and its's fine with a cheap coil. Never felt the need for a sports coil especially as they're a bit blingy for me
Vegard
Post by Vegard »
As a matter of fact, this started when I changed to a gold coil. Seriously :)
Could the misfire come from this as well?
JC T ONE
Post by JC T ONE »
Vegard wrote:As a matter of fact, this started when I changed to a gold coil. Seriously :)
Only one way to find out ;)
Jack of all trades
Post by Jack of all trades »
When we were racing in the '90s we had loads of problems with the Lucas sports (gold) coil, we swapped to the old SA12 with the brown top http://www.google.com/imgres?q=lucas+sp ... 9,r:4,s:68 and all the problems were solved. It never failed in 3 seizons.
sandman
Post by sandman »
Lucas coils are known to cause problems... I would swap back and try.
I always carry a spare - which come to think of it - you now got Vegard (hehehe) :)
Cheers,
Ed_
Vegard
Post by Vegard »
sandman wrote:Lucas coils are known to cause problems... I would swap back and try.
Indeed, and see where it got me...A lost race :P
