sound deadening
Nick W
sound deadening
Post by Nick W »
I know you cant see it when the cars all built up, but I hate to see modern looking sound deadening. This stuff seems about the best I can find....any one found any thing else that looks old??.
Up North in Sheffield
Has thanked: 138 times
Been thanked: 117 times
Re: sound deadening
I know what you're saying NIck but........... Be wary about using the old stuff* that you show because it absorbs atmospheric moisture like it's going out of fashion and as it does so, it's out of sight and out of mind. The modern stuff has by far, far superior sound absorbent and deadening qualities and ain't absorbent
* I think that it's called compressed cotton waste
Toby
Has thanked: 12 times
Re: sound deadening
Post by Toby »
The one in your picture does look spot on Nick with regards to originality
Nick W
Re: sound deadening
Post by Nick W »
Peter Laidler wrote:I know what you're saying NIck but........... Be wary about using the old stuff* that you show because it absorbs atmospheric moisture like it's going out of fashion and as it does so, it's out of sight and out of mind. The modern stuff has by far, far superior sound absorbent and deadening qualities and ain't absorbent
Hi Peter
this stuff is called Needle loom felt....yes I see your point, I think its one of those things that after Ive spent months rebuilding a car, Im unlikely to let moisture get in to my car to any degree...look at door cards ..made of compressed card board, and we have all seen what moisture can do to them. but Ive never had an issue with this on any of my cars, as I dont use them like they would have been used back in the day. if a car does get used like say a modern car, left out in the winter, used in any condition like( Rich's) cars, then it will rot no matter what you do to stop it. so for me I prefer to use original materials even if its not as technically good as the modern equivalent.
Nick
Hipwell
Re: sound deadening
Post by Hipwell »
Does look a close match.
Does this also lie inside the boot?
Andrew1967
Re: sound deadening
Post by Andrew1967 »
Very nice by the looks. 8-)
I get what you are saying Peter but if the car isn’t going to get wet or be exposed then the felt deadening should be fine. I have similar in the FY ‘S’ and all is well some 13 years after fitting up. I’m
Nick W
Re: sound deadening
Post by Nick W »
Hipwell wrote:Does look a close match.
I Suppose it could do the boot but if you find some original ..I would use it for the real authentic look.
sheds quite a bit of fibres that can be anoying but you can stop this if you use some hair spray laquer on it I think..
AndyPen
Has thanked: 18 times
Been thanked: 50 times
Re: sound deadening
Post by AndyPen »
Here is a pic of my unmolested genuine '64 boot material - may help as reference?
NZmember
Re: sound deadening
Post by NZmember »
With the black painted battery well too.
Is the felt glued into place or just laid?
Where else do you have insulation? Under the rear parcel shelf, rear seat, rear wheel arches? I've got to do this myself one day so I am interested to find out all the places that should have the jute felt insulation.
Andrew1967
Re: sound deadening
Behind the dash panels and roof skin
Thinner, similar felt on the door skins and rear quarter panels.
goff
Re: sound deadening
Post by goff »
Toby wrote:The one in your picture does look spot on Nick with regards to originality
It aint scruffy enough , so cannot be spot on :lol: :lol: :lol:
360gts
Been thanked: 53 times
Re: sound deadening
Post by 360gts »
Looked at the website...they have a 1/4" felt that might be ideal for the doors and rear quarter panels....
the rear parcel shelf has a really thick piece ...approx. 1" thick....think a double thickness of their 1/2: would be ideal.
Anyone looked at their wool carpet.....wonder how it compares to Martrim etc!!
Toby
Re: sound deadening
Post by Toby »
360gts wrote:Anyone looked at their wool carpet.....wonder how it compares to Martrim etc!!
Have you used Martrim in the past, if so what's the quality like?
360gts
Re: sound deadening
Post by 360gts »
Hi Toby
No, haven't decided yet on which to use on my 970 and the 1071......have a lot of samples that look quite good.
Still waiting to hear if the dark gray Veltone (BAS) will ever happen. Talked to Rebecca last week....not much happening on the development of this color. Said they are so busy...don't have the staff/time to focus on it!
AndyPen
Re: sound deadening
Post by AndyPen »
NZmember wrote:With the black painted battery well too.
Hi, I am away at the moment but can check the car when I get back next week. BTW is the black original then? I did wonder as the car is virtually untouched as far as I'm aware?
jl46
Re: sound deadening
Post by jl46 »
Andy,
Can you tell us the thickness of your original boot insulation. I'm guessing it is 1/2 ".
It looks like the Needlefelt 1/2" would be a very close equivalent to the factory original.
AndyPen
Re: sound deadening
Post by AndyPen »
jl46 wrote:Andy,
Yes of course, I'll check when I return later this week.
johnv
Re: sound deadening
Post by johnv »
Slightly off topic but does the insulation in the boot and on the parcel shelf actually make much of an impact on cabin noise?
Mk2 1968 Cooper 998 TPL555F
Mk1 1965 Cooper 1275 BFC110C
Nick W
Re: sound deadening
Post by Nick W »
johnv wrote:Slightly off topic but does the insulation in the boot and on the parcel shelf actually make much of an impact on cabin noise?
Yes...but the biggest difference I found with sound deadening was the under bonnet and bulkhead area.
Polarsilver
Has thanked: 38 times
Been thanked: 52 times
Re: sound deadening
Post by Polarsilver »
Apologise to ask in this thread :oops: .. but has anyone used these modern self sticking sound reduction pads on the cannot be seen areas such as the the inside back of Bulkhead & behind Door Cards etc .. have seen it used on a mk1 Golf & the noise reduction was significant & this modern stuff does not absorb moisture.
