Under Bonnet Insulation
wanganui 1071
Post by wanganui 1071 »
Can anyone post a photo of the original under bonnet insulation for a 1963 mk 1 cooper S. Im assuming it is glued as one piece to the underside of the bonnet
Any help appreciated.
360gts
Been thanked: 53 times
Re: Under Bonnet Insulation
Post by 360gts »
wanganui 1071 wrote:Can anyone post a photo of the original under bonnet insulation for a 1963 mk 1 cooper S. Im assuming it is glued as one piece to the underside of the bonnet
Yes, it is glued to the bonnet.
Cammsjb
Post by Cammsjb »
Any chance of some measurements of the insulation in the photo?
Simon776
Post by Simon776 »
The very first of that type don't have the depression for the Cooper air filter box - now they are super mega rare.
Hipwell
Post by Hipwell »
What are they made of, just foam? No repros available?
winabbey
Has thanked: 5 times
Been thanked: 15 times
Post by winabbey »
Hipwell wrote:What are they made of, just foam?
BMC engineering drawing for this part says its phenolic resin bonded fiberglass coated with neoprene paint.
wanganui 1071
Does any know the thickness of this insulation ? Many thanks
wanganui 1071
Im trying to establish the thickness of the insulation .I would like to try and reproduce a close
copy. Any more photos would be a helpful..Ive found nothing in NZ to copy to date .Unless there is a nz forum member who can help?
Many thanks
winabbey
Post by winabbey »
Nominal thickness is 0.75" with thinner sections above the air box and under bonnet strengthening ribs.
A Mini enthusiast here in Australia reproduced a small quantity using similar but not the same material. I don't know if any more are in the pipeline.
rolesyboy
Has thanked: 19 times
Post by rolesyboy »
I have an original one in my loft. I will add a few photos at the weekend if you like.
Cheers. Mark
Rolesyboy
wanganui 1071
thank you that would be real handy
wanganui1071
Post by wanganui1071 »
Can anyone help me with some close up photos so i can have a go at reproducing the under bonnett insulation .This is the project i wish to add the finish detail too
Many thanks
winabbey
Post by winabbey »
How is this?
wanganui1071
thank you very much Can I trouble you to take a photo of the other side please Many thanks
wanganui1071
Do you know what the 2 dropped sections are designed to clear ? The air cleaner is the back one Thanks again
AndyPen
Has thanked: 18 times
Been thanked: 50 times
Post by AndyPen »
wanganui1071 wrote:Can anyone help me with some close up photos so i can have a go at reproducing the under bonnett insulation .This is the project i wish to add the finish detail too
Many thanks
Great to see another 1071 looking so good, do you have a thread on here to show more? Mine's in many many bits ;-)
Hipwell
Post by Hipwell »
wanganui1071 wrote:Do you know what the 2 dropped sections are designed to clear ? The air cleaner is the back one Thanks again
Presume they line up with radiator cap and front corner of radiator itself.
Gray
Post by Gray »
Looking good, where did you get the buckle clip that is holding the heater hose to heater air intake trunk? I cannot find any that long. Cheers.
Been thanked: 9 times
More pics.
wanganui1071
Thanks all for replying. Gray the clips I just made them Had an original profiled it and had them water cut out The ali is softer so you cannot work thm back and forward .But they do the job. Pity you are in uk as i still have a few laying around.
