Hi.
I'm restoring a 1962 997cc Cooper. The car came with a set of MG (I think) carbs which I am using and the spacers seem to be far to thick (about 15-20mm approx) My friend with a 1275cc Cooper S reckons his are only about 6mm think.
Does anyone know the correct thickness they should be on a 62 997 Cooper?
Any help welcome.
Thanks!
Steve
Twin 1inch 1/4 carb spacers
- SteveG
Re: Twin 1inch 1/4 carb spacers
thanks littler. I have a correct 997 inlet manifold now which has shown up the spacer problem.
Would the spacers be the same on all mini 1 1/4 inch SU carbs ?
- Toby
- Has thanked: 7 times
- Been thanked: 3 times
As you have a 62 car the spacers ought to be aluminium, those should be the 1/4 inch thick ones.
T.
- SteveG
I've just managed to get a pair of original ally ones so all good.
Cheers for the help
Cheers for the help
