Twin 1inch 1/4 carb spacers
SteveG
Post by SteveG »
Hi.
I'm restoring a 1962 997cc Cooper. The car came with a set of MG (I think) carbs which I am using and the spacers seem to be far to thick (about 15-20mm approx) My friend with a 1275cc Cooper S reckons his are only about 6mm think.
Does anyone know the correct thickness they should be on a 62 997 Cooper?
Any help welcome.
Thanks!
Steve
littler
Re: Twin 1inch 1/4 carb spacers
Post by littler »
there about 1\4" thick,
you should have a 12A309 manifold also
SteveG
Post by SteveG »
thanks littler. I have a correct 997 inlet manifold now which has shown up the spacer problem.
Would the spacers be the same on all mini 1 1/4 inch SU carbs ?
Toby
Has thanked: 12 times
Post by Toby »
As you have a 62 car the spacers ought to be aluminium, those should be the 1/4 inch thick ones.
T.
littler
Post by littler »
ive got a pair , send me a pm if you want them.
SteveG
Post by SteveG »
I've just managed to get a pair of original ally ones so all good.
Cheers for the help
