Engine Steady Bar Distance Piece
- Mini4Ever
Does anybody know when the distance piece for the engine steady bar was deleted?
I know that it was still there in December 1965 but what happend after that? I am trying to figure out whether my December 1967 Mk II Cooper should have one or not...
Too many cars...
Re: Engine Steady Bar Distance Piece
If we are talking about 21A1106 does anybody have any dimensions to make one up, or would someone have one spare?
- Toby
according to Somerford the distance piece was deleted in 1970, so it should be on your car.
T.
- Mini4Ever
Yes, I meant washer 21A1106. Can anybody confirm that it was deleted as late as the Somerford catalogue suggestes according to Toby?
I can measure one up tonight for the exact dimensions.
Too many cars...
No wonder I didn't know what you were on about, I'd never seen one of those before.
Part number 30.
Part number 30.
- Mini4Ever
Yes, that's it!
Diameter of inner hole: 8.45mm
Diameter of outer ring: 18.95mm
Thickness: 5.40mm
They were introduced in Jan 1963, but when were they deleted?
Thickness: 5.40mm
Too many cars...
- Mini4Ever
Cheers Bart, I can make one now as I have been trying to find one for ever. Gray
Without having a look I'm pretty sure that 2 manifold washers fit perfectly
Cheers, Ian
Cheers, Ian
- Toby
I can sense a batch job of these just around the corner for you Gray
T.
- sandman
I normally use 3 or 4 regulare 5/16" washers as a distance piece...
Cheers,
Ed_
Ed_
