Ignition Leads & Plug Cap Fittings
Hipwell
Post by Hipwell »
Firstly should a 1966 Mini have carbon type leads? Are Green Spark Plug ones Ok?
Secondly are the clips for the plug caps available from anywhere?
GSP only sell one type of clip which is not that similar to the originals?
Not my pics...
66S
Re: Ignition Leads & Plug Cap Fittings
Post by 66S »
A few years ago I tried unsuccessfully to source the clips. The outfit that sells the repro Champion caps does not sell just the clips. The green cable I used on my '66 S is copper cored and I believe this is correct for '66.
Regards
Has thanked: 208 times
Been thanked: 80 times
Try Sommerfords. I'm not suggesting here that they will have what your after, but they do have a selection of period fittings.
It would appear that Copper Leads were used up to the late 60's.
cpr1
Post by cpr1 »
I have used Champion/Ripault hypalon green carbon cored wire , when fitted, there's no visual difference to the copper cored wire.
Toby
Has thanked: 12 times
Post by Toby »
Th Green Spark Plug Company sells leads and connectors:
http://www.gsparkplug.com/1x-spark-plug-cap-clip.html
Been thanked: 10 times
I agree with Toby, The clips that GSC sell work fine with any early plug.
Hipwell
Post by Hipwell »
Toby wrote:Th Green Spark Plug Company sells leads and connectors:
Yes, but they don't give much detail on them, are they suitable for the caps, are they crimped on?
They aren't crimped on, they slide on with the spike down the conductor.
When the cap is pushed into place it pushes the little clip bit into the insulation which holds it all together.
cpr1
Post by cpr1 »
Have used them many times, have some original Lucas Hypalon wires carbon cored if anyone is interested.
