Radiator
BLT
Radiator
Post by BLT »
Hi. Can anyone describe what an early '65 998 radiator looks like, or better still post a photo. I've ended up with 4, all different and all mk1 I think, but have forgotten which is the right one what with flat tops, round tops, drain taps, brass, plugs, Coventry this and that etc. Cheers :?
BLT
Re: Radiator
Post by BLT »
I think it's the Coventry flat top with 16 gills and a drain tap?
smithyrc30
Re: Radiator
Post by smithyrc30 »
BLT wrote:I think it's the Coventry flat top with 16 gills and a drain tap?
Isn't that the Cooper one? Would also have the letter C stamped into the vertical section of the frame.
I thought the originals were 13 fins per inch, with a drain tap.
mzmini
Re: Radiator
Post by mzmini »
ditto :)
Mini Cooper S 1964 Mk1 - International Rally winner red & white
Mini Cooper S 1964 Mk1 - Road Rally champion green & white
Mini Cooper S 1971 Mk3 - original and unrestored
BLT
Re: Radiator
Post by BLT »
It is a Cooper, a 998 Cooper. They're not all 'S's :D
ivor badger 2
Re: Radiator
Post by ivor badger 2 »
was 16 gill not the export rad at that time with 13 for a std S and 11 for a std mini
BLT
Re: Radiator
Post by BLT »
According to Parnell's book, 16 gill introduced late '64 and rounder top mid '65. The fan was 16 blade standard and 6 blade for hot climates.
