Smiths tachometer wiring
Re: Smiths tachometer wiring
Hello guys
The engine starts and runs well,
But the revcounter doesn't work...
I'm totally sure about the wiring,
I already tested the eletricity from + and - to the rev counter it works,
I tried to switch the distributor wire with the coil, and to adjust the lenght of the buckle
It doesn't work! I feel like screaming lol
- Been thanked: 10 times
Thats the problem with these very old induction loop tachos. they often dont work.
Probably not an answer you want to hear but look at these. Great quality & super retro look.
viewtopic.php?f=9&t=14216
Hello Mark!
Thank you
I know them,
I prefer to keep my old one,
Perhaps I made a mistake but I tried everything to make it work
I replaced every cables to start with a brand new wiring
Thank you
I know them,
The induction loop wire can be very sensitive to wire thickness, length of wire & size of loop.
To be honest if you have absolutely no reading at all on your tacho it is probably knackered, but if you want to continue to try, I would suggest you concentrate on the white induction loop wire, if your tacho is working then this wire will be the key to getting a reading.
I appreciate you want to keep the original, but if it was mine, I'd stick it on a shelf & call it a collectable.
Induction loop tachos are crap.
I totally agree with you mark,
but my father asked me to fit an old one,
As for the indection buckle
I replace the wire, but with exactly the same material
The buckle is the same,
I don't know, I will try to find a shop that could help me
These can be tested & repaired.
This guy does good work & can convert to impulse at the same time.
http://www.jdo1.com/rev_counters.html
- dklawson
If you suspect your tach is dead, look at the tach conversion boards sold by Spiyda Design. As long as the meter portion of your RVI tach works, the board will both restore it to functionality and update it to a voltage pulse sensing tach.
https://www.spiyda.com/magento/index.ph ... board.html
Doug L.
Thank you guys!
I will buy a tacho conversion RVI to RVC
Does anyone know how to open the speedo?
I already unscrewed the bold at the rear, but impossible to open it
- Nick W
The needle needs pulling off , this can be tricky .I send mine to Spyda . There are insructions on utube if you want to try
Nick
Nick
Up North in Sheffield
Hello Guys,
I think about buying a new one,
Ok spydia, can repair the eletrical fault but, if the problem comes from the mechanical part.. I prefer to leave it like that,
I already contacted specialist, a total refurbishment will cost me about 120 pounds.. a new one will cost me about 130 pounds..
- Nick W
I have a spare one like yours in working order
£20+post
I can show you a video of it working
Nick
£20+post
Nick
Hello
Finally I bought a brand new one.. not vintage but it works perfectly..
I 'll post some pictures tonight
Thanks guys
Thanks guys
