Halda T gears
abri
Halda T gears
Post by abri »
Hi all,
I managed to get my hands on a Halda Speedpilot Mk IV. I'm a complete noob to these and was considering selling it on, but I started reading up and am wondering what T-gears are used to fit these to a Mini? The unit came with a "gearbox" screwed onto the back of it that says 7.5:1 on it. It also came with a T-gear that has V14 and 8:1 on it. I assume one needs a short length of cable to connect between the speedo and the T to remove it slightly back from the tight area in the binnacle right behind the speedo?
Basically I'd like to know which T gears and cables people use to fit these to a Mini.
Thanks for any advice
JC T ONE
Re: Halda T gears
Post by JC T ONE »
Dr S
Re: Halda T gears
Post by Dr S »
Real halda bits look very pricey... How ever speedy cables seem to be able to make up junction boxes and cables with different ends. That's my plan for when I get it installed..
mini129
Re: Halda T gears
Post by mini129 »
You need a v12 for a mini plus the other 7.5:1 drive.
abri
Re: Halda T gears
Post by abri »
Thanks for the reply. I have V16 to swap for a V12 then if anyone is interested.
