Seat Belts
Spitz
Seat Belts
Post by Spitz »
My new to me 62 Traveller does not have seat belts. It does have the high up mounting point with a bolt in place on both sides of the car.
Can I assume that they were an option for the NA market that early?
I see no fittings at the bottom ( although I've not pulled back the carpet )
Been thanked: 11 times
Re: Seat Belts
Post by Old English White »
The mountings were fitted by then (the lower one will be behind the carpet) but belts didn't become a compulsory fitting in the UK until 1965 I think?
Tupers
Re: Seat Belts
Post by Tupers »
The 2nd mounting point should be on the inner sill just in front of the rear bin.
You can just about see it in this pic.
Pete
Has thanked: 59 times
Been thanked: 148 times
Re: Seat Belts
Post by Pete »
As Richard says, belts were a dealership or aftermarket option in the early 60's.
Spitz
Re: Seat Belts
Post by Spitz »
Thanks for the replies…….but would the factory put the bolt in place (upper)
I'll have a look for the bottom mount later today
I've not been able to find out if belts needed to be fitted here in CA at that time.
Re: Seat Belts
I think they left the factory with a plastic grommet in the upper mounting hole if memory serves me? Not a bolt anyway.
Gareth Brandt
Re: Seat Belts
Post by Gareth Brandt »
High mounting had a washer (24A 1356) and metal clip button (14A 9631) lower had a plastic bolt (14A 9922) and tunnel had rubber gromets (14A 9668)
Pete
Re: Seat Belts
Post by Pete »
Old English White wrote:The mountings were fitted by then (the lower one will be behind the carpet) but belts didn't become a compulsory fitting in the UK until 1965 I think?
The rule was that by 1965 if your car had been registered in that year you had until December to put belts in and compulsory thereafter.
