My new to me 62 Traveller does not have seat belts. It does have the high up mounting point with a bolt in place on both sides of the car.
Can I assume that they were an option for the NA market that early?
I see no fittings at the bottom ( although I've not pulled back the carpet )
Seat Belts
Re: Seat Belts
The mountings were fitted by then (the lower one will be behind the carpet) but belts didn't become a compulsory fitting in the UK until 1965 I think?
Re: Seat Belts
The 2nd mounting point should be on the inner sill just in front of the rear bin.
You can just about see it in this pic.
Re: Seat Belts
Thanks for the replies…….but would the factory put the bolt in place (upper)
I'll have a look for the bottom mount later today
I've not been able to find out if belts needed to be fitted here in CA at that time.
Re: Seat Belts
I think they left the factory with a plastic grommet in the upper mounting hole if memory serves me? Not a bolt anyway.
Re: Seat Belts
High mounting had a washer (24A 1356) and metal clip button (14A 9631) lower had a plastic bolt (14A 9922) and tunnel had rubber gromets (14A 9668)
- Pete
- Has thanked: 59 times
- Been thanked: 148 times
Re: Seat Belts
The rule was that by 1965 if your car had been registered in that year you had until December to put belts in and compulsory thereafter.Old English White wrote:The mountings were fitted by then (the lower one will be behind the carpet) but belts didn't become a compulsory fitting in the UK until 1965 I think?
