Early heater motor
970s
Early heater motor
Post by 970s »
Hi, does anyone had the experience to change the motor's rotation direction by switching over the positive and negative terminals from battery ? I found my mk1 fan motor (with two white leads ) , turns to only one direction (wrong direction as indicated by the arrows on the fan vane) whatever I connect it to negative earth or positive earth setup! Can I change the motor's field by short circuit it like the dynamo?
Al :roll:
Has thanked: 204 times
Been thanked: 76 times
Re: Early heater motor
Sounds like it has wound field coils instead of permanent magnets. If so, then you need to swap over either the field wires or the armature (brush) wires to change it's direction. Swapping both (as in the input wires as you've done) won't do it. I'm not sure I am familiar with your particular fan motor, but some can be turned end for end to reverse the rotation.
