SU fuel pump breathers
davidmuir
Has thanked: 18 times
Post by davidmuir »
Just about to fit an SU pump(don't know what make is on but it's small diameter and sticks!). Suction/discharge and electrical connections are obvious..........what's the perceived wisdom on the breathers?...........going to siamese them with small bore tubing. Can't see/find any reference/pictures of the breathers.
minimans
Re: SU fuel pump breathers
Post by minimans »
There just that breathers, you can tee them together just make sure they face down so they don't act like mini funnels for water................
Has thanked: 206 times
Been thanked: 79 times
If it's any help, here's a factory recommended way of doing it (nearly all Cooper S's made here were set up this way from the factory);-
However, I wouldn't bother looking for the 'Rivet - Nylon P/N 13H1640' as they are very thin on the ground.
minical
Post by minical »
I have one of the nylon rivets if you are looking for one. Cheers
davidmuir
Post by davidmuir »
Thanks folks, knew you'd know!
850man
Post by 850man »
dragging up a old thread, can anyone confirm that the breather "rivit" 13H1640 has been remade? If so where can I buy them from?
smithyrc30
Post by smithyrc30 »
Dunno about re-made but here is one:
http://www.ebay.com.au/itm/Breather-for ... 35eb9a6a22
AU$125 :shock:
dklawson
Post by dklawson »
I am no purist and would not pay that sort of money for a part that is hidden under the car... but to each his own.
Were I looking for an alternate, I would consider some of the Luer Lock (syringe) fittings that adapt small bore tubing. Take a look at the plastic parts near the bottom of the page linked below.
http://www.mcmaster.com/#quick-turn-tub ... gs/=xjatvr
You could use a barbed fitting and pass its Luer lock through the hole in the heel board and fit a Luer nut on the inside to secure the fitting in place.
Doug L.
JC T ONE
Post by JC T ONE »
So the difference on a AUF200 and AUF201 is only the small breather pipe on the metal housing ? or are there other ways to spot a AUF200 ?
