After 20 odd years the engine is running again. It has been completely rebuilt and I have installed a new dynamo from mini spares, new control box, and new coil. It has been set up with negative earth.
I cannot get the ignition light to go out when the engine is running.
Any suggestions gratefully received.
Ignition light
Re: Ignition light
Try this topic. There may be an answer in among the replies.
viewtopic.php?f=3&t=8164&hilit=Ignition+light
- dklawson
Re: Ignition light
The PDF linked below discusses generator and control box tests and may also prove useful.
http://mgaguru.com/mgtech/books/pdf/Luc ... _Tests.pdf
and this one...
http://www.justbrits.com/Articles/Lucas05.pdf
and this one...
Doug L.
Re: Ignition light
All now sorted thanks. Flashed the dynamo and encourage the points in the control box and all now well.
