Somerford repro Radiator cowlings
Jamie
Post by Jamie »
Hi,
I have seen Somerford are now selling repro two piece radiator cowlings - just had my original radiator restored and my existing lower cowling is a bit bent and has cracked in a few places so I was thinking of buying one of theirs. Has anyone bought one of them?
They do two versions one for all models except cooper and cooper S models (RADCOWL001) and one for cooper and cooper S models (RADCOWL002). Could anyone tell me what the difference is between the two versions? They look exactly the same in the pictures to me!
I have a 1275 engine in my mk1 so I'm not sure if i would need the Cooper/Cooper S version or not?
I'm sure I must be using my original cowling from my 850 engine currently, so i'm just trying to understand what the differences between the two versions are!
Its probably something obvious that I havent thought about!
Many thanks
Jamie
Re: Somerford repro Radiator cowlings
The difference is the spacing of the mounting holes on the bottom.
These are made by M-Machine, available direct http://www.m-machine.co.uk/
Jamie
Post by Jamie »
Thanks Mark, i'll measure the mounting holes on mine then and give Mini Machine a call instead.
Appreciate your help.
Jamie
skorstensfejeren
Post by skorstensfejeren »
As Mark said... the different are in the bottom,. The bracket are placed to take the cowl a little bit closer to the engine, or else it will hit the innerwing. talking about 10mm..
The holes are the same, but the "nomally" cowl wont fin the Cooper and S engine... its too close to the inner wing....
The ones from sommersford look good, ive seen them...
NicholasUpton
Post by NicholasUpton »
Actually, the radiator is in the same location just the different lower mount/bracket gives pulley clearance, by moving the mounting location.
Jamie
Post by Jamie »
Thanks for that Nicholas, that's really useful....I'm sure that I'm using the 850 version currently, I always thought it was very tight getting the bolts in by the pulley, think I will change the lower bracket at the same time to the cooper s version.
Jamie
