Fuel sender problems
Hi Guy´s...
Hope someone might help a lillte here...
I got the sender ( FTZ2330/00 and the gauge ( FG 6233/05 ).. They should work together, right??..
Can anyone tell me how to test them. They are all on the table in front of me.. The sender seems to works fint ( with the ohmmeter ) But can get the gauge to work, it just moves a little bit????? should it goes to full right away wgen you put 12v on it?
Anyones knows how can I test it together with 12V here
All the best
All the best
Re: Fuel sender problems
Thanks Surfblue...
But mine dosen´t have a voltage stabilizer.. ist pre late 64...
skorstensfejeren wrote:Problem is now fixet.. its all working..
- Frogeye61
I was not aware that a pre- late 64 would not have the voltage stabilizer. Admittingly I don't have the speedometer in my early 64, and I don't remember the configuration of my 61 and other 64, but I have owned nearly a hundred British cars from late 50's to mid 60's and don't remember seeing one without the stabilizer.
From what I remember
, the old units would "average" just about 10V by switching on and off with about a half second to one second frequency, though the frequency would change depending on the battery voltage. This, though slow, is at a faster frequency than the gauges could respond. Therefore the gauges appeared to remain relatively stationary. The newer replacement units just use a "proper" semiconductor voltage stabilizer which gives a constant 10V.
- Has thanked: 4 times
- Been thanked: 23 times
The early one works on a different basis to the later ones. The early gauge is a moving iron meter and the sender unit makes up the variable resistor of a wheatstone bridge (Rx in the diagram below) which is a method of calculating the resistance of an unknown resistor, independent of voltage.
Early senders have a nominal resistance range of 3-83 ohms, whereas the later ones are 220(ish)-20 ohms and work in the opposite direction.
Tim
Tim
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
1955 BSA C11G
1969 Triumph TR6R
