Thread on temp sender port?
Benny
Post by Benny »
What is the thread size on the temperature sending unit port, near the thermostat housing? I seem to remember 5/8" UNC, but wanted to confirm.
rich@minispares.com
Re: Thread on temp sender port?
Post by rich@minispares.com »
5/8 unf
Benny
Post by Benny »
Thanks Rich.
Has thanked: 199 times
Been thanked: 75 times
rich@minispares.com wrote:5/8 unf
Ah Rich, you can be my Valentine :D
ianh1968
Post by ianh1968 »
5/8" by 18 TPI UNF, as already stated...
...Same thread as the block banjo bolt hole for the
oil-pipe, certainly on "non-late" (pre 90ish?) models...
If you're after a tap to just clean out the threads,
consider getting a "plug tap" as on some heads the
sender hole is not full-bore all the way through and a
taper or second tap will bottom out before cleaning up.
NB: Some capillary type temp gauges have a "gas" type
fitting which is 3/8" BSP (19 TPI). This size and 5/8" UNF
are very similar and it is sometimes possible to screw the
BSP end of the adapter into the head. You then end up with
a leaking system as the BSP nut connection does not seal
properly on the UNF thread.
Ian
