1275 gt 7" discs to 7.5"conversion
Steve A
Post by Steve A »
Hi, my friend has a set of early 7" disc assemblies on his mini which he thinks came from an early 1275gt. I have driven the car and the brakes are awful! :shock: Is is a case of new calipers and discs from minispares as I am not sure if they will fit on the same hubs? Any advice?
Smiffy
Re: 1275 gt 7" discs to 7.5"conversion
Post by Smiffy »
Early GT's had the same brakes as a cooper S, which would be the 7.5 inch variety.
In the shed
Post by In the shed »
It's been a while since I drove my mini. If you are used to a modern car, they take a bit of using!
I think it's probably driver perception.
Steve A
Post by Steve A »
Not entirely sure if they are early gt then as they are definitely 7" but i am going on information which came with the car.
I have 7.5" s set up on my mini and they are good.
What I need to know is if the 7.5 calipers and discs and will fit? Lets assume that they are early cooper then?
Cheers Steve
Has thanked: 199 times
Been thanked: 75 times
The only part in common between the 7" and 7.5" Disc set up is the hub, everything else is different.
STG95F
Post by STG95F »
I need a 7" discs set up if you want to sell Steve A ??
PM Me ;)
Thanks Ian
Steve A
Post by Steve A »
Hi Ian, they don't belong to me i am just helping someone but i think they will be changed for 7.5 s set anyway so they may well be available i will have to let you know cheers Steve
Vegard
Post by Vegard »
STG95F wrote:I need a 7" discs set up if you want to sell Steve A ??
PM Me ;)
Thanks Ian
I've got one for sale. Complete bar hubs and one drive flange.
STG95F
Post by STG95F »
Steve & Vegard PM me the details
thanks Ian
