Another boot board bracket question!
minical
Post by minical »
I'm currently restoring a mk2 cooper, I will be fitting boot board brackets for 165 tyres....so am I right in thinking that the ones on the bulkhed will need moving 20mm higher up or have I got that wrong? Cheers
JC T ONE
Re: Another boot board bracket question!
Post by JC T ONE »
Not sure how much higher ? but yes - they need to go higher.
just put the 165 next to a 145 & mesure the difference ?
Oh and they need to be fitted to a rim, as they go wider, when inflated.
1071 S
Post by 1071 S »
You will also need to trim the board down - they need to be narrower as they go higher....
Cheers, Ian
minical
Post by minical »
Thanks for the replies. I'm now thinking against the taller brackets as there is a lot of messing around. Might keep a 145 tyre as a spare instead?
Pete
Has thanked: 57 times
Been thanked: 147 times
Post by Pete »
minical wrote: Might keep a 145 tyre as a spare instead?
Sounds the best option. ;)
That's what I do.
KA2S4
Post by KA2S4 »
minical wrote:Might keep a 145 tyre as a spare instead?
Same here.
J
SteveG
Post by SteveG »
James knows alot about spare wheels... just saying..
