WINDSCREEN HEATED HIDDEN Works MS86
Posted: Mon Nov 11, 2013 9:43 pm
by HRD
Hi All,
I bought a windscreen for my Austin Cooper replica Works, i wonder how can i connect it, can you help me please.
Information: There are 3 connections on windscreen.
Regards
Pierre
Re: WINDSCREEN HEATED HIDDEN Works MS86
Posted: Tue Nov 12, 2013 1:57 pm
by pad4
HI
Do you have the Monte Carlo type with silver strips visible on the screen - If so the outer 2 wires are the live feed and the central wire is the earth
Now it depends if you want the whole screen to work or the left side / right side / both sides - this is where it gets a little complex
Pad
Posted: Tue Nov 12, 2013 8:01 pm
by Ronnie
Hi
As Paul has inferred it all depends on the switch! Have a look here >>
http://mk1-performance-conversions.co.u ... heated.pdf
This may be of assistance this diagram is not for the works switch!! If you understand electric diagrams on the works cars the switch ( P13-1-7530 A) varies the earth and power connections on the screen. let us know what switch you are using and we may be able to help.
Paul (Pad 4) Does this Stanton switch (that seems prevalent on E-bay) switch the screen correctly, 1/4 Power, Full power, Drivers side only
Posted: Tue Nov 12, 2013 8:35 pm
by HRD
Hi All,
Thanks you for the replies.
This switch that i will use for my car. (white/Black Lucas)
Posted: Tue Nov 12, 2013 8:56 pm
by Ronnie
Posted: Tue Nov 12, 2013 10:04 pm
by HRD
Ok thanks for informations.
My Switch OFF/ON is Lucas 56SA. It's good ?
"ln SchemeI the heating elements are connected in parallel for operation at full power only"
Posted: Wed Nov 13, 2013 12:56 pm
by Ronnie
HRD wrote:Ok thanks for informations.
Yes & Yes !
But you probably only need 10 Amps for short periods (thats a lot of current!). That is why they used the timer or TOK
Posted: Wed Nov 13, 2013 1:06 pm
by HRD
Ok, thank you very much for help.
Now i'm looking for the sheme electric for wiper automatic as ex-works car.
Regards
Pierre
