H4 twin SU rebuild
970s
H4 twin SU rebuild
Post by 970s »
Hi, Just started to rebuild my twin H4 SU set, wonder if anyone remember should I soaked the floatbowl gasket in fluid before fitting? in gasoline or oil or what fluid ?.... should I change the medium bronze loat to a smaller diameter one? Like Swiftune kits used to do!
Thanks for advise!
Al ;)
Re: H4 twin SU rebuild
The gasket can be fitted dry, and although fitting the smaller float was a popular racing tweek a while ago, the standard float works better for road use.
970s
Post by 970s »
:D Thanks Mark!
How's you Speedwell project goung?
Al
You are welcome!
How's you Speedwell project going?
Not at all, I haven't touched it in about 3 years. I am however starting to think about doing it again. So, watch this space.
johnsimister
Post by johnsimister »
Re the floats, what are the pros and cons of the standard-size float versus the smaller one? Why is one better for racing and the other for road? I ask because my supercharged 850's H4 has the smaller float in a chamber able to take the bigger one, and I was wondering why this should be.
John
rich@minispares.com
Post by rich@minispares.com »
john
it just means that there is an extra reserve of fuel in the float chamber 'on demand' if your really thrashing it
johnsimister
Thanks, that makes sense. Could be useful given the little beast's sometimes voracious thirst. I'll leave it as is.
John
