crank identification. 1275 1100 970 1071
migliacars
Post by migliacars »
This morning I was sorting out my cranks from 1000cc to 1275cc piles.
I pulled out a crank labelled up 1000cc mini, but it had the stepped crank tail.
It has been balanced and lightened so there are no marks on it except
ESC1A
I measured the big ends and there 1.625.
the label which is hand written states
mains standard
bg standard
thrusts standard
its cross drilled on the big ends
on the crank its self there is ,s, written on it in white paint.
all my cranks have come from a mini tuning company.
how will i determine what crank it is
do any 1100cc cranks have the stepped crank tail?
do any 970 or 1071 cranks have stepped tails
ricardo
Re: crank identification. 1275 1100 970 1071
Post by ricardo »
migliacars wrote:do any 1100cc cranks have the stepped crank tail?
No.
migliacars wrote:do any 970 or 1071 cranks have stepped tails
Yes... and 1275. Are there any AEG stamps? Try to measure the stroke.
Has thanked: 125 times
Been thanked: 34 times
As it's been machined, you'll have to do as migliacars suggests;-
migliacars wrote: Try to measure the stroke.
which is easiest done in a block, or between centres (like in a lathe, but spun by hand).
Without measuring (or part numbers), anything else is a guess.
Yes, the South African 1100 crank has a stepped tail & GT size journals.
Only way to determine what your crank is is to measure the stroke.
mk1 wrote:do any 1100cc cranks have the stepped crank tail?
Just to clarify Mark's post a little more, the SA 1100 Engines were a short stroke big bore, not the 1098 small bore.
Very true.
