arden head and big journal rods
Posted: Tue Dec 18, 2012 7:37 pm
by 5portsrock
Hi, has anyone fitted an Arden head to an engine with big journal con rods? if so what was requird to make them fit? Thanks alot
Re: arden head and big journal rods
Posted: Tue Dec 18, 2012 8:03 pm
by guru_1071
it can be done by machining the rod way so the stud clears the cam, but its an unelegant solution thats far from ideal
Posted: Tue Dec 18, 2012 9:03 pm
by 251 ENG
Just use some H beam rods
Posted: Tue Dec 18, 2012 11:25 pm
by Vegard
251 ENG wrote:Just use some H beam rods
Yup, I've tried and found this as well with Saenz con rods.
Posted: Wed Dec 19, 2012 6:03 am
by Astro
Hi,
just some modifications.
Posted: Wed Dec 19, 2012 10:30 am
by 5portsrock
Thanks for that, i gather from the picture youve machined the spot face where the rod bolt head sits and possibly reduced the edge of the rod ? Anymore detailed info would be appreciated.
Astro wrote:Hi,
Posted: Wed Dec 19, 2012 11:33 am
by Astro
Hi,
nothing more than can see and you mentioned. But you should care about the peace of the thread now looking downwards. Otherwise it will contact the gearbox housing.
Perhaps I should add. What you see is a standard crank of a 1293 engine. It’s just made for standard inlet valves. If you will use one of the new competition heads with 37mm or more inlet valves, you will need 73.5mm pistons and a short stroke crank if you need to keep the 1300ccm.
Best regards
Posted: Sat Dec 29, 2012 9:55 pm
by Fanfaniracing
hopp!
i have done this on my arden-headed engine last year.
whe machined down the seat of the bolt by 2,5 mm so it would not touch the camshaft.
the engine worked very well but failed becuse the new arden head was repaired with some araldite glue... ( no coment...)
regards fabian
Posted: Sat Dec 29, 2012 10:47 pm
by Vegard
2.5mm from a 1.75" journal rod? Sure you don't mean 1.625" rods?
Posted: Sun Dec 30, 2012 1:27 am
Vegard wrote:2.5mm from a 1.75" journal rod? Sure you don't mean 1.625" rods?
I think he means the spot facing for the stud head was dropped a further 2.5 mm (which may also require shorter studs? )
Posted: Sun Dec 30, 2012 7:48 am
by Astro
Yes, on the photo you saw a 1.75 big end journal and at the second con rod you have to cut the stud for the same 2.5mm. Otherwise it will contact the gearbox housing.
Posted: Sun Dec 30, 2012 8:59 am
by Vegard
Ok. When I measured the same thing, it seemed to be more than that to make things go around (!)
Posted: Sun Dec 30, 2012 9:48 am
by Astro
Maybe that it is the Swift SW 23 8-port cam installed at 0°.
Posted: Sun Jan 06, 2013 9:15 am
by Fanfaniracing
The Rods i used were innocenti rods so they were 1.75" rods i supose?
Posted: Sun Jan 06, 2013 10:23 am
by 5portsrock
Fanfaniracing wrote:The Rods i used were innocenti rods so they were 1.75" rods i supose?
Yes, Innocenti rods are big journal. Did yo have to modify them in a similar way ? and by how much?
