arden head and big journal rods
5portsrock
Has thanked: 11 times
Post by 5portsrock »
Hi, has anyone fitted an Arden head to an engine with big journal con rods? if so what was requird to make them fit? Thanks alot
guru_1071
Re: arden head and big journal rods
Post by guru_1071 »
it can be done by machining the rod way so the stud clears the cam, but its an unelegant solution thats far from ideal
251 ENG
Post by 251 ENG »
Just use some H beam rods :D
Vegard
Post by Vegard »
251 ENG wrote:Just use some H beam rods :D
Yup, I've tried and found this as well with Saenz con rods.
Astro
Post by Astro »
Hi,
just some modifications.
5portsrock
Thanks for that, i gather from the picture youve machined the spot face where the rod bolt head sits and possibly reduced the edge of the rod ? Anymore detailed info would be appreciated.
Astro wrote:Hi,
Astro
Post by Astro »
Hi,
nothing more than can see and you mentioned. But you should care about the peace of the thread now looking downwards. Otherwise it will contact the gearbox housing.
Perhaps I should add. What you see is a standard crank of a 1293 engine. It’s just made for standard inlet valves. If you will use one of the new competition heads with 37mm or more inlet valves, you will need 73.5mm pistons and a short stroke crank if you need to keep the 1300ccm.
Best regards
Fanfaniracing
Has thanked: 8 times
Been thanked: 22 times
Post by Fanfaniracing »
hopp!
i have done this on my arden-headed engine last year.
whe machined down the seat of the bolt by 2,5 mm so it would not touch the camshaft.
the engine worked very well but failed becuse the new arden head was repaired with some araldite glue... ( no coment...)
regards fabian
Vegard
Post by Vegard »
2.5mm from a 1.75" journal rod? Sure you don't mean 1.625" rods?
Has thanked: 199 times
Been thanked: 75 times
Vegard wrote:2.5mm from a 1.75" journal rod? Sure you don't mean 1.625" rods?
I think he means the spot facing for the stud head was dropped a further 2.5 mm (which may also require shorter studs? )
Astro
Post by Astro »
Yes, on the photo you saw a 1.75 big end journal and at the second con rod you have to cut the stud for the same 2.5mm. Otherwise it will contact the gearbox housing.
Vegard
Post by Vegard »
Ok. When I measured the same thing, it seemed to be more than that to make things go around (!) :)
Astro
Post by Astro »
Maybe that it is the Swift SW 23 8-port cam installed at 0°. :roll:
Fanfaniracing
The Rods i used were innocenti rods so they were 1.75" rods i supose?
5portsrock
Fanfaniracing wrote:The Rods i used were innocenti rods so they were 1.75" rods i supose?
Yes, Innocenti rods are big journal. Did yo have to modify them in a similar way ? and by how much?
