Johnny wrote:Thank you for the replys.
I was planning to use the Restall, but now the Microcell seems more practical. It is a little hard to get in and out of the Restall. I will get in touch with Gareth for some more help.
The Restalls came from ebay too. The guy had four of these Type 5 seats, he did not know what they were. I got a pair in one auction. Here is a picture of the other one. I don't know if it was ever used. I need a new rubber base for it though. It does not have a Mini subframe either.
Another seat I picked up is this one. I Think it is a Corbeau? Probably not desirable but has a similar look. Always wondered what it was.
Thanks for your time,
John
You're welcome John.
Personally speaking ,I find your seats really interesting
and to "happen upon" 4 Type 5's in one go,that's just incredible.
Regarding your 'Type 5' ,I believe the subframe is genuine 'Restall' item ,there should be 'RB' (Restall Bros) or just 'B' stamped on the side rail(zoom in on pic 1) .Because of the sheer height of it ,I would put my money on it being for the 'VW Beetle'.(see pic 2) Probably originally supplied through the 'EMPI'/Speedwell' connection ?
The correct 'Restall' 'Mini 'subframe circa 1965 on ,is .(see pic 3)
Q. Are the parallel marks on the front bolster, just an imprint where something has been resting on it or is it a stitched feature?
Q. Is the rubber diaphragm a 'Vitafoam' P116 ,with expansion springs to compensate for the extra width ?or perhaps you would be good enough to post a photo,for me. Thanks
Regarding the other seat,I think it's a real gem and it is definitely not 'Corbeau' . To be perfectly honest I can't ID myself ,yet!
It's a real teaser,with it's triangular fibreglass shell it looks late 60's Porsche 911 'Recaro',yet uncannily the trim bears all hallmarks of a 'Restall'
Not only is trimmed in the same format and uses the usual basket weave and plain vinyl fabrics ,but take for instance the "flap" centre panel construction .Particularly the edge detail and where the "shoulders" meet the sides.Then there is the base cushion,with the trademark "slashback " nosing and the top stitching detail across where the 2 fabrics meet,which I have never seen from any other manufacturer.
Therefore ,please would you also post or PM pic's of ;
1.The underside of the base cushion.
2.The underside of the shell
3.The back of the shell.
Cheers for now
Gareth
