spring clutch on a "non" small tail crank
814CWE
Post by 814CWE »
opened an engine/box up,ive had in the lock up for years, of unknown origin,to find spring clutch on a normal size taper crank and not the small tail crank as the norm...???
no engine number or id marks.. but the car was a 63 it was removed from back in 1987..again no identity marks-all i know it was grey/white but this means nothing i suppose.
its not an 850 i know for sure .bore size looks more like 1275 approx 70 mm (dished pistons) and a quick rough measurement of
the stroke- approx 68 mm which seems the same as an 850
its deffo been rebuilt at some time with a 10 thou grind on both journals.
i assume this is some kind of overbored hybrid ?
Vegard
Re: spring clutch on a "non" small tail crank
Post by Vegard »
1071? :)
814CWE
Post by 814CWE »
you tell me???
251 ENG
Post by 251 ENG »
Bore and stroke match a 1071 , does the block have AEG 151 cast on the back ?
814CWE
Post by 814CWE »
dunno-ill have a look tomorrow
im not getting my hopes up,its prob something sombody has cobbled together
did the 1071 have a spring clutch?????
Has thanked: 199 times
Been thanked: 75 times
Yes.
InimiaD
Post by InimiaD »
The Diaphragm clutch was introduced during September 1964 on the 850 models.
The 1071 had the Diaphragm clutch from April 64.
814CWE
Post by 814CWE »
this just gets better and better
999 ORX
Post by 999 ORX »
Was there a rainbow hovering above the block? ;)
814CWE
Post by 814CWE »
no
just a bit of good luck for a change,as normally if i didnt have bad luck,,id have none at all
814CWE
Post by 814CWE »
251 ENG wrote:Bore and stroke match a 1071 , does the block have AEG 151 cast on the back ?
simon,,no aeg number in back,,tho shows signs of things been ground off and theres a peg where the engine size tag obviosly used to be-
BRI MK1
Post by BRI MK1 »
is it for sale cheers brian.
251 ENG
Post by 251 ENG »
Post some pictures up
814CWE
Post by 814CWE »
yes ill sort some when back at garage tomoz...
i still think its some kind of hybrid-sombodys deffo been messing!!
