How do folks
What are your thoughts on me running the weber with no air filter? Is it a bad idea?
No air filter
- tomkidd
- Pete
- Has thanked: 39 times
- Been thanked: 105 times
Re: No air filter
Depends on how the car's used Tom. For the odd track event it's not gonna cause you issues but if you're going to do 1000's of miles a year on the road it may well do. Best compromise is to use socks for road use.
- Lord Croker
Re: No air filter
I agree with Pete, I used to run my rally Mini without filters, but as I used it on the road as well, bore wear was appreciably higher than in my present Mini with K&N, which has done around 110,000 miles on original bores & pistons which are still looking good. Upper cylinder lubricant in the fuel can help offset extra wear caused by running without filters, I always used the old type Redex, sadly no longer available, so I use Red Line lead substitute, not only a UCL but also a sodium based oil to protect valve seats.
Re: No air filter
Its okay to run for light drag racing, quick hill climbs and rally stages maybe few laps (dependin on track)
But gotta take into account weather.
To dry = dust = more wear
to wet = weaked mixture and all sorts of problems
cold with dry air = perfect ;] nice and dense
alot of factors to take into account.
- Vegard
